Date/Time: Mon, 24 Feb 2025 15:12:36 +0000
Moving over all settings and layouts from broker provided sierra
View Count: 442
[2021-03-16 22:13:24] |
User409644 - Posts: 45 |
Can you tell me how to get my main page with all of my control buttons and layouts moved over to my new direct sierra account ? I have alot of custom bars that will take forever to recreate. There must be a way to move it over. Thank you. |
[2021-03-17 09:03:05] |
Yes this is possible. This is contained within the Sierra4.config file which you need to copy. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-17 09:03:17
