Date/Time: Sat, 04 Jul 2026 03:31:23 +0000
Denali+Rithmic
View Count: 903
[2021-03-16 21:24:22]
User491299 - Posts: 26
Good day, Is it possible to connect two different datafeeds at the same time? Need to use them both on computer.
[2021-03-17 13:42:55]
John - SC Support - Posts: 47017
As long as the data feeds are for different exchanges, then it is possible. If one of the data feeds is from Sierra Chart, then this is a normal operation and really does not need anything special to be done. Any exchanges for which you are not getting real-time data from Sierra Chart you will get from your other source (assuming it is setup for real-time data).
If you are using two data feeds where both are not Sierra Chart, then it get a bit more complicated, and you will have to have 2 installations to receive the data. You can then port the data from one installation to the other, but it is a bit of a complex setup. You will find the instructions for all of this on this page:
Using Multiple Data and Trading Services at the Same Time
Note the section entitled "Accessing Market Data from Other Instances of Sierra Chart".
[2021-03-17 19:04:58]
This page has everything you need to know:
