Date/Time: Mon, 24 Feb 2025 15:42:30 +0000
Broken Link in Documentation for Numbers Bars Calculated Values Study
View Count: 493
[2021-03-16 18:10:29] |
User247273 - Posts: 37 |
I was reading the documentation for the Numbers Bars Calculated Values study Numbers Bars: Numbers Bars Calculated Values Input Descriptions I got a 404 error when I followed a link called Calculated Values Background Coloring Logic Numbers Bars: Numbers Bars Calculated Values Input Descriptions Is there a different place I can find this info? P.S. Thanks for making excellent software. |
[2021-03-16 19:30:24] |
John - SC Support - Posts: 38117 |
The correct link is the following: Numbers Bars: Calculated Values Background Coloring Logic We found one of the errors and will check the rest to make sure they are correct and get them fixed (if necessary). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
