Date/Time: Mon, 24 Feb 2025 15:18:07 +0000
Can not trade live yet.
View Count: 445
[2021-03-16 16:41:35] |
User104714 - Posts: 25 |
Hello, I am all set up with AMP/CQG and Denali yet I only see an option for sim trading in SC. When I take if off simulation mode, the account drop down box only says "unset" Please advise, thanks. |
[2021-03-16 16:53:50] |
John - SC Support - Posts: 38116 |
You have not setup your Sierra Chart software to connect to your CQG Account. Make sure you go through all the items in the Setup Instructions here: CQG Trading Platform Service: Setup Instructions When you complete all those steps, then open your Chartbook(s) and select Edit >> Translate Symbols to Current Service. You should be fine after that. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
