Date/Time: Mon, 24 Feb 2025 15:06:49 +0000
Connexion WIFI Data Feed connect
View Count: 543
[2021-03-16 15:22:37] |
Crystal77 - Posts: 28 |
Hi, This morning i cant connect data feed market with WIFI, but if i do a connexion sharing with my phone in 4G, all works and SC can connect.. i control WIFI connexion and all worked, WIFI working, but NOT for connected SC... Yesterday all working.. what happened ? thanks for your help |
[2021-03-16 16:14:44] |
John - SC Support - Posts: 38116 |
If you can connect using your phone, but not WiFi, then that means there is a problem with your WiFi. You would need to look into why that is happening. We cannot help with something like that as it is definitely something with your setup.
[2021-03-17 06:05:48] |
I try many hours to find a problem,.. not working. i never change nothing in setup or in SC.. All working with my phone. can help me or where i can check in SC setup or Windows 10 ??? i not find a solution!!!! thanks for your help John !!! |
[2021-03-17 09:03:50] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed with File >> Connect to Data Feed. After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
