Date/Time: Mon, 24 Feb 2025 15:38:55 +0000
Sierra Charts not showing data anymore for live data
View Count: 887
[2021-03-16 15:22:26] |
VKS19 - Posts: 7 |
I am not able to see live data on Sierra Charts. Also shows zero on the quote board for volume.
[2021-03-16 16:12:57] |
John - SC Support - Posts: 38116 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
