Date/Time: Mon, 24 Feb 2025 21:13:37 +0000
Open price on 10 tick range bar chart is incorrect
View Count: 676
[2021-03-16 14:20:20] |
User329455 - Posts: 19 |
I noticed that the opening price for EPM21 (3/16) was 3961.50 on my 10 tick range bar chart, but it was 3963.50 (correct price) on my 5 tick range bar chart. I deleted the 10 tick, duplicated the 5 tick and changed it to 10 tick and still had the same problem (i.e., this new 10 tick chart says that open was at 3961.50, which is incorrect). Version: 2237 (I updated last week to this version and just noticed this problem today). I don't remember having this problem on the previous version I was using. Date Time Of Last Edit: 2021-03-16 14:25:25
[2021-03-18 14:16:40] |
Check the Session Times: Chart Session Times And also New Bar at Session Start: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-24 17:31:48] |
Enabling New Bar at Session Start fixed the problem. Thank you!
