Date/Time: Mon, 24 Feb 2025 15:20:55 +0000
Developping value area on Profile Charts
View Count: 451
[2021-03-16 08:42:56]
DenysL - Posts: 3
Hiya,
I know you can have the developping value areas on a regular chart with the Volume Value Area lines study, but I would like to have it on the Profile chart as well. This is because if you open a running profile, you can't see where tests below value were because value was not there at that point. So I guess my question is, can you have developping value area lines like you have in the Volume Value Area lines study on a running market profile.
Cheers!
[2021-03-16 10:48:15]
If you are referring to a TPO Profile Chart, the answer is definitely not.
Date Time Of Last Edit: 2021-03-16 13:45:48
