Date/Time: Sat, 18 May 2024 07:58:09 +0000
[User Discussion] - Gann Swing
View Count: 2183
[2014-03-03 13:27:48] |
User15451 - Posts: 27 |
Dear Support & Kiwi, You have provided your Gann Swing for use and the code on a prior occasion. The alignment is off by one bar. This first came to my attention when writing an alert in a Spreadsheet and noticing that it did not populate properly. After making an adjustment in the Code [POS] and re-compiling it worked great. Now for some reason the next-day reloading everything the alignment is off again, Very odd. Thank you for your support |
[2018-08-26 22:33:38] |
User629461 - Posts: 162 |
Hi User15451, was there a reply to this message? I'm interested in the Gann Swing code if you're able to share? Many thanks J |
[2020-04-10 15:58:23] |
Thurston - Posts: 9 |
I am also interested in the Gann Swing code. Thanks in advance.
[2020-04-10 16:24:22] |
Ackin - Posts: 1865 |
Try this: https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/Kiwi.cpp |
