Date/Time: Mon, 25 Nov 2024 19:48:04 +0000
where do you you change this font color?
View Count: 1054
[2014-03-03 13:12:18] |
infpz - Posts: 826 |
Image attached.
[2014-03-03 18:46:25] |
This is documented at step 9 here: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-03 18:47:27
[2014-03-03 18:52:35] |
I found the place to adjust the color of the flag, but I am missing where to change the color of the texts, sorry.
[2014-03-04 00:31:16] |
The actual text foreground color cannot be changed.
