Date/Time: Mon, 24 Feb 2025 15:05:15 +0000
Which package to choose?
View Count: 525
[2021-03-15 16:12:00] |
SkyKeeper - Posts: 40 |
It used to be Package3 + Denali Exchange Data Feed Which one should I choose now? use CQG WebApi Package10 ? |
[2021-03-15 17:28:32] |
John - SC Support - Posts: 38116 |
Yes, you will want to use Package 10 and make sure you go through the Denali Exchange Data Feed Setup Instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-16 02:37:03] |
Also make sure that you tell your broker you do not need any market data from CQG. You will be using market data provided by Sierra Chart.
