Date/Time: Mon, 24 Feb 2025 16:22:47 +0000
cuenta real
View Count: 563
[2021-03-15 16:03:25] |
User262338 - Posts: 1 |
yo tengo una cuemta real con ampfutures y ya la conecte con sierra chart pero expiro mi cuenta demo de sierra y no adquiero datos de mi cuenta real no me me brinda los datos por que la cuenta demo sale no conectada
[2021-03-15 17:21:14] |
John - SC Support - Posts: 38122 |
From Google Translate: I have a real account with ampfutures and I already connected it with sierra chart but my sierra demo account expired and I do not acquire data from my real account, it does not give me the data because the demo account is not connected
We are not understanding the particular issue you are having. The account from which you posted this message is a Trial account and has time available until March 21, 2021. If you are trying to connect your Sierra Chart software to AMP, then they should have set you up with CQG. If this is correct, then follow these instructions to connect your Sierra Chart software to CQG: CQG Trading Platform Service: Setup Instructions If you need help with something else, then please give us the specific information of the problem. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-18 13:48:11] |
For now we recommend you use the Delayed Exchange Data Feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
