Date/Time: Tue, 25 Feb 2025 04:15:13 +0000
Different Position Lines
View Count: 673
[2021-03-15 15:29:55] |
awakef - Posts: 72 |
Hi I'm having trouble on my position lines when executing orders for example: I enter buy market EUR futures at 1.19570 and I see the buy position line with no problems but when the the price climbs to 1.19640 and I want for example enter a market short position without closing my original buy order, my buy original position line disappear and it only shows my short market position line. How can I have my original buy position line without disappearing and also my short position line? Thanks for the awesome software! |
[2021-04-03 23:46:50] |
Up
[2021-04-04 16:37:54] |
Sawtooth - Posts: 4175 |
Sierra Chart doesn't support hedging. You can't have simultaneous long and short positions in the same symbol in the same account.
Date Time Of Last Edit: 2021-04-04 19:48:18
[2021-04-04 16:47:21] |
Thanks Tomgib! You know if Sierra will support that on the future? |
[2021-04-04 19:52:30] |
Hedging and FIX compliance
[2021-04-05 00:17:25] |
Thanks Tom!
[2021-04-05 02:50:48] |
Refer to: Trading Information Windows: Only Single Consolidated Position Maintained and Displayed per Symbol and Trade Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
