Date/Time: Mon, 24 Feb 2025 16:33:32 +0000
Chart scrolled to the end
View Count: 620
[2021-03-15 10:40:07] |
User645832 - Posts: 99 |
Is there a way to set the charts to always be scrolled to the end (last candle) by default when I open them?
[2021-03-15 11:05:33] |
This happens automatically. If you have an issue, refer to: Working With Charts: Charts Unexpectedly Scroll Back and Change Fill Space Amount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-15 11:17:00] |
I checked these issues, these are not the reason. What happens is the chart 'remembers' where I left it, what I want is that it will 'forget' it and always present the last candle next time I open it, |
[2021-03-17 21:16:59] |
Charts are always scrolled to the end, when they are opened. There is no way to change that. Maybe a custom study is changing the position of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-18 04:37:47] |
What do you mean be 'when they are opened'? I have many charts opened at once but only one is active. When I switch to a different chart (that was already opened) I want it to be scrolled to the end, even if I left it in a different position. |
