Date/Time: Mon, 25 Nov 2024 18:51:59 +0000
Open E Cry - Error connecting to data or trading service
View Count: 1188
[2014-03-03 11:59:05]
User49732 - Posts: 8
Since this morning I don't receive any intraday data. Can you help me?
Thank you!
Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-03-03 12:53:55
Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-03-03 12:53:55
Error received in OnConnect while connecting. Windows error code 10060: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato. | 2014-03-03 12:54:16
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-03 12:54:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-03 12:54:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-03 12:54:16
Disconnected from Open E Cry. | 2014-03-03 12:54:16
[2014-03-03 17:19:23]
This problem should now be resolved. It was an issue on the OEC side.
To connect, select File >> Connect to Data Feed.
Date Time Of Last Edit: 2014-03-03 17:20:43
