Date/Time: Tue, 25 Feb 2025 07:05:17 +0000
[Programming Help] - Sierra Indicator
View Count: 1136
[2021-03-14 23:41:52] |
User161806 - Posts: 18 |
Hi there, I currently have top of book data with AMP. I have a friend that is trading on ninja trader with these indicators (see image) and they also are using top of book data. I was wondering if there is an indicator/s which would show the same information (delta, delta percentrage, total volume) - please see image Thanks for your time. Kind Regards, Josh |
[2021-03-14 23:48:55] |
Also forgot to mention the histogram to visually see change as well. Thanks!
[2021-03-15 10:48:25] |
binaryduke - Posts: 378 |
Numbers Bars: Displaying Numeric Information Below Numbers Bars You can also play with how you display the numeric values if you want to achieve a histogram. Top of book liquidity vs full book liquidity makes no difference to displaying traded volume. Why would it? |
[2021-03-15 10:56:46] |
Thanks for your reply. I have tried this indicator but for some reason the value does not show. I was under the impression that you needed full book for it to work?
[2021-03-15 11:12:04] |
You need Sierra Chart Advanced Package. Sounds like you do not have this.
[2021-03-15 11:22:32] |
Yes I have package 3 - thanks for your help
[2021-03-15 15:30:30] |
User584084 - Posts: 266 |
Take a look at Sierra Chart Service Package 5. This is what you might be looking for. Sierra Chart with Advanced Features (Service Package 5) Price: 36 USD/month Sierra Chart with Advanced Features includes all of the Standard Service Package features and these additional advanced features: TPO Chart Study Numbers Bars Numbers Bars Calculated Values Market Depth Historical Graph Volume Profile Interactive Drawing Tool |
[2021-04-07 09:48:59] |
Ackin - Posts: 1865 |
I was wondering if there is an indicator/s which would show the same information (delta, delta percentrage, total volume) - please see image Thanks for your time. Kind Regards, Josh ticinotrader: https://twitter.com/TicinoTrader/status/1377248060338700288/photo/1 |
