Date/Time: Mon, 24 Feb 2025 15:32:04 +0000
Delta bars
View Count: 1213
[2021-03-14 19:51:39]
Vito Anasto - Posts: 4
Can I create a similar chart in Sierra Charts to the chart in the link below?
https://gyazo.com/aa574ce9015d939e2252fd09da0f9d97
[2021-03-15 16:25:41]
John - SC Support - Posts: 38116
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2021-03-15 20:30:52]
Hi
I do not currently have Sierra Charts. i Would like to know if I can duplicate that chart before I purchase.
[2021-03-15 21:11:27]
Yes you can. Those are Numbers Bars set to show the Delta (we also have Diagonal Delta if desired). Refer to the following documentation:
Numbers Bars
[2021-03-16 12:25:43]
Thanks,
Can the bar also show the outline of the candle? OHLC the way it displays in the screenshot?
Also, Do you have a large trade indicator, that shows large block trades?
[2021-03-16 13:55:58]
The option to show the bar outline is found here:
Numbers Bars: Open and Close Marker Style
Refer to the following study:
Large Volume Trade Indicator
