Date/Time: Mon, 17 Mar 2025 18:28:08 +0000
Incorrect .dll filename when compiling multiple files
View Count: 1756
[2021-03-14 19:09:15]
autobahn - Posts: 27
v2229 64-bit (36135)
When compiling multiple files, the filename of the resulting .dll created in the data folder is not as expected.
Current behaviour:
The .dll is named after the first file returned by the "Select an Advanced Custom Studies files(s)" dialog.
Expected behaviour:
The .dll should be named:
1) according to that specified in SCDLLName(); or
2) match the name of the .cpp file that contains SCDLLName().
[2021-03-15 14:11:46]
The issue is caused because the "Select an Advanced Custom Studies file(s)" dialog is returning the selected files in an indeterminate order. I would expect the files to be returned in the order selected, or the file containing SCDLLName to be moved to the front of the list.
[2021-03-18 13:38:20]
We will look this over.
[2022-09-17 16:44:24]
jwick - Posts: 142
Hi! Is there any update on this? I am experiencing the same issue on v2439. The order that the files are sent to the compiler appears to be the sort order on the Select Files open dialogue box. Depending on the sort order, .lib / .dll files are accordingly created / not created.
