Date/Time: Mon, 25 Nov 2024 19:26:07 +0000
Point of Control for a bar.
View Count: 1491
[2014-03-03 11:29:34] |
2garin - Posts: 184 |
Good day. How can I display the Point of Control on the current bar (candle)? How can I display the Point of Control in a closed bar (candle)? Thank you. |
вопрос 1.png / V - Attached On 2014-03-03 11:26:19 UTC - Size: 19.05 KB - 464 views |
[2014-03-04 18:06:15] |
You could use the Volume Value Area Lines study and set the Time Period for the lines to be the same as the chart bars time period.
