Date/Time: Thu, 06 Mar 2025 19:18:47 +0000
TPO - adding side by side VBP studies
View Count: 1572
[2021-03-14 18:00:01] |
User884572 - Posts: 7 |
Hi, I'm trying to add 2 VolumeByPrice studies to a 30min TPO profile. One profile is daily session and the other profile is to be current 30min period. I have accomplished this by having 2 VBP studies one based on TPO and the other set as independent, however this isnt really optimal and would like to know if possible to have side by side profiles both based on the TPO profile. one daily and one current 30min period? Also is it possible to only show the VBP study for the current session agian from being based on TPO profile and not independent? thanks http://www.sierrachart.com/image.php?Image=161574476642.png |
[2021-03-15 15:55:52] |
John - SC Support - Posts: 38450 |
To do what you are asking for requires that you create the Volume by Price studies as separate from the TPO studies. Refer to the following for an example of how to do this: Volume By Price Study: 30 Minute Volume Profile at End of TPO Profile Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-15 16:06:48] |
hi, thanks for the respose however that is what i followed to apply the 30 min TPO independant VBP study that i have now as shown in the above screenshot. . What i am trying to accomplish is having the 30min VBP study attached to the TPO study aligned with the daily session total volume. Does this make sense? Basically the way i have it now it stays aligned to the far right regardless of any chart scaling, moving..this is very cumbersome being as TPO charts are constantly being moved around throughout the trading day. Is there any option for this? or is the above screenshot the best i can get? side note: im coming from windotrader so looking to have a layout similar if at all possible... |
[2021-03-15 17:27:26] |
The way the Volume by Price within Sierra Chart works is that when you have a TPO chart you can only either have the VbP associated with the TPO for all TPOs. Or you can have the individual VbP(s) displayed on the right side apart from the TPO profiles.
[2021-03-15 17:33:19] |
ok so i have it setup the best way available.. maybe that feature will be added later.. thanks
[2022-02-11 06:45:55] |
Agassi - Posts: 3 |
Hi User884572: Can you please share your template? I also would like to know how you had created the TPO chart that looks like windotrader chart! I am new to Sierra. Thank you |
