Date/Time: Thu, 17 Sep 2026 05:42:27 +0000
2 Questions: Order Quantity Hotkeys & Order Types.
View Count: 912
| [2021-03-14 12:37:30] |
| Tr@der17 - Posts: 12 |
I was trying to set 12 different order quantities using the Global Settings > Customize Keyboard Shortcuts. Is there a way to do more than 6 of these? The custom ones didn't seem to give me an option to set different order quantities beyond just the 6. Can it be done? Also, on the chart that I have the char trading menu on, I have "Simple Bracket" selected as the order type. Is there a way to make this automatically be the order types when I enter the trade in via chart trading and/or keyboard shortcuts on other charts. Thank you in advance. |
| [2021-03-14 13:44:08] |
The answer is no to the first question. For the second question, refer to: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-14 13:44:52
