Date/Time: Mon, 24 Feb 2025 18:20:35 +0000
[User Discussion] - Charbook Tabs
View Count: 638
[2021-03-14 05:44:34]
User94606 - Posts: 327
Prior to version 2238, my charbook tabs were displaying on the bottom. After the upgrade, the chartbook tabs disappeared. I went to Global Settings -> General Settings -> and set the tabs for MDI Window at Bottom (see screenshot) but it does not work. Any ideas how to fix this issue?
imageTabs.jpg / V - Attached On 2021-03-14 05:43:59 UTC - Size: 462.95 KB - 255 views
[2021-03-17 13:12:05]
Any updates?
[2021-03-19 16:17:39]
User490716 - Posts: 7
In my case after upgrade, when I'm switching between chatbooks, MDI window disappears for a moment and then after 1 second it reappers, really annoying, this is some new bug.
