Date/Time: Sun, 04 Oct 2026 19:41:34 +0000
disable popups in replay mode
View Count: 822
| [2021-03-13 20:34:41] |
| User61576 - Posts: 458 |
how do I prevent the following windows from jumping and covering my screen when I replay a chart and get an order filled? 1. message log window 2. trader orders windows |
| [2021-03-15 14:32:40] |
| John - SC Support - Posts: 48095 |
1. The Message Log should not be coming up unless there is a problem that needs to be looked into, in which case you should deal with the underlying issue of why it is opening. Or if you are using a 3rd party study that is opening the Message Log to give some information, then you should modify the code to not open the Message Log. But, if you want to set the Message Log to not open at all, then refer to this setting (note that this is a general setting and not specific to replays): General Settings Window: Never Automatically Open Message Log or Trade Service Log (Global Settings >> General Settings >> Log >> Log) 2. We are not sure what window you are referring to in this case. If it is the Trade Service Log, then refer to the information above and the same setting. If it is something else, then let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
