Date/Time: Sat, 19 Sep 2026 11:58:31 +0000
Looking for more info on SC w/ Tradovate setup
View Count: 1081
| [2021-03-13 20:01:30] |
| User720788 - Posts: 1 |
1. As it appears that only the CQG connection is avaiable at this point, are performance stats using the CQG web api available? How would the SC/CQG web api performance compare to the SC/TT routing service for example? 2. Would I be able to use the data feed from Tradovate or would I need to purchase another feed for use with SC? Jigsaw for example can connect to the Tradovate feed and routing directly using Tradovate login credentials. |
| [2021-03-15 14:27:49] |
| John - SC Support - Posts: 47939 |
1. We do not have performance information for the CQG WebAPI connection. 2. In theory, the answer is Yes, as it is CQG data. Just be aware there may be issues related to the number of connections to that data feed. You would need to ask your broker about this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-18 14:34:20] |
1. As it appears that only the CQG connection is avaiable at this point, This is not true. We recommend using the Sierra Chart Order Routing Service. This is available with other brokers:Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
