Date/Time: Mon, 24 Feb 2025 12:06:17 +0000
sc.GetEndingDateTimeForBarIndexFromChart access violation
View Count: 441
[2021-03-13 02:27:56] |
User735389 - Posts: 189 |
recently updated to the newest version of SC. sc.GetEndingDateTimeForBarIndexFromChart is giving me an access violation error. I switched to sc.GetNearestMatchForDateTimeIndex which i think will work for me. Not sure if the change to sc.GetEndingDateTimeForBarIndexFromChart was intentional, didnt see anything in the documentation.
[2021-03-13 08:30:33] |
You should not get an exception with that function. Recompile your source code for the current version of Sierra Chart.
