Date/Time: Mon, 24 Feb 2025 12:47:06 +0000
Label column
View Count: 1117
[2021-03-12 22:39:23]
Technical - Posts: 158
MY charts have a dom and a label column. The dom takes up too much real estate, but I do need the labels. Can I hide or remove the dom but keep the labels?
[2021-03-12 23:13:47]
John - SC Support - Posts: 38116
Deselect the option for Chart >> Chart Settings >> Advanced Settings >> Hide Values Scale, and then use Trade >> Show Market Data Columns and do not turn on the option for "Trading Chart DOM On".
Refer to the following:
Chart Settings: Hide Values Scale (Chart >> Chart Settings >> Scale menu)
And the following:
Trade Menu: Show Market Data Columns (Trade menu)
[2021-03-12 23:45:03]
Excellent, thank you. Can I also turn off the bid/ask columns? See attached.
imageBid Ask.png / V - Attached On 2021-03-12 23:44:39 UTC - Size: 6.88 KB - 265 views
[2021-03-13 08:41:34]
Refer to:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
[2021-03-14 12:58:40]
Thank you.
I do not see an option to remove/hide or tighten the bid/ask columns.
Let me know if I am missing something.
[2021-03-14 13:55:41]
The columns cannot be removed, but you can remove the market depth quantities within them.
