Date/Time: Mon, 24 Feb 2025 13:20:45 +0000
highlight open for each new subgraph (yellow boxes)
View Count: 604
[2021-03-12 19:55:06] |
User754185 - Posts: 3 |
Hello, How do I change the feature to add or turn off the yellow boxes to highlight the open for each new subgraph period? Can these boxes be turned on for other subgraph periods? |
[2021-03-12 19:58:57] |
John - SC Support - Posts: 38116 |
Refer to this setting: Time Price Opportunity (TPO) Profile Charts: Highlight Sub Period Midpoint Letter/Block We are not sure what you mean by "Can these boxes be turned on for other subgraph periods?". There is also this option: Time Price Opportunity (TPO) Profile Charts: Highlight Open Of Each New Sub Period Within TPO Profile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-13 01:03:41] |
Can the colored box or blocks be used to highlight the open or the close in a subgraph period other than highlighting the midpoint?
[2021-03-15 13:34:56] |
There is the following setting for highlighting the Open, which uses a different color (not the box itself): Time Price Opportunity (TPO) Profile Charts: Highlight Open Of Each New Sub Period Within TPO Profile There is no option to highlight the close of each subperiod. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
