Date/Time: Mon, 24 Feb 2025 12:02:01 +0000
Heat map
View Count: 798
[2021-03-12 17:16:44] |
User575399 - Posts: 326 |
I noticed my heatmap is not workinng correctly since rolling contracts? Any ideas why? thank you
[2021-03-12 17:32:06] |
John - SC Support - Posts: 38116 |
Most likely the Lowest Quantity for Coloring setting is too high. Given how the depth values are showing it would appear that numbers less than about 200 are set to not display.
