Date/Time: Wed, 18 Nov 2026 10:11:23 +0000
ATR move indicator
View Count: 919
| [2021-03-12 13:03:09] |
| User645832 - Posts: 99 |
Hello Can anyone assists in finding an indicator that prints the 1 ATR line above and below the open of the current candle only? (see attached from a different platform) Thanks! |
| [2021-03-12 15:35:16] |
| John - SC Support - Posts: 48568 |
We are not sure exactly how the lines are being calculated, but we can give you one idea of what we think you are looking for and you can tweak from there. First add the ATR study as you want to the chart. Then add a Spreadsheet Formula study and set the Number of Bars to Calculate to 1. Then enter the following for the Formula: =(H + L) / 2 + ID1.SG1 Where ID1.SG1 is the Subgraph of the ATR. It may be a different ID in your case. Then set the Subgraph Draw Style for the Spreadsheet Formula to Dash. Also be sure you set the Region for the Spreadsheet Study to Region 1. Refer to the following for the ATR study: Average True Range Refer to the following for the Spreadsheet Study: Spreadsheet Formula Refer to the following regarding referencing studies in alert formulas (which is what the Spreadsheet Formula uses): Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart And refer to the following for Subgraph Draw Styles: Chart Studies: Subgraphs Tab >> Draw Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-13 08:00:45] |
| Marmany - Posts: 319 |
You may also find it useful to look at the SuperTrendStop study if using ATR as a basis for setting stop loss.
