Date/Time: Mon, 24 Feb 2025 12:19:26 +0000
Is my data feed realtime ?
View Count: 513
[2021-03-12 05:19:12] |
amangalore - Posts: 23 |
Please confirm. If not which package should I upgrade to ?
[2021-03-12 15:02:07] |
John - SC Support - Posts: 38116 |
You are not getting any Real-Time data from us (Sierra Chart). What are the exchanges for which you want real-time data? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-12 15:22:53] |
Some symbols are real-time with the Service Package that you have. It depends what markets you want real-time data for. For complete details about real-time market data, refer to this page: Real-Time Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-12 15:23:08
