Date/Time: Mon, 24 Feb 2025 12:17:19 +0000
Demo service for LMAX
View Count: 511
[2021-03-11 23:18:51]
User858042 - Posts: 3
this is just a comment after a week of test.
I find the LMAX datafeed very slow compared to FXCM which is very quick. I trade only the US30 (FXCM) / WS30m (LMax).
On LMAX, I have a lot of gaps on the 1Mn chart that I don't have with FXCM (meaning data are missing).
I don't know if you have anything to do on your servers or if it depends only on the flow that LMax sends you.
In the second case, maybe you can send them my remark.
But if Lmax is at its best performance, I will not open a Live account, this is not tradable.
As I use CFDs, my only choice will be IB but I am aware of the technical problems you have with their protocol...
I miss really FXCM, but as I told you, I am french and can't anymore trade with FXCM UK that has a link with Sierra (because of Brexit).
Thanks for your support anyway.
Christophe
[2021-03-13 14:56:21]
ForgivingComputers.com - Posts: 1012
The demo LMAX data feed does not represent the live LMAX data feed. They are not the same.
You can get a demo account with LMAX and use the live data feed and get more accurate Sim results.
