Date/Time: Mon, 24 Feb 2025 12:13:40 +0000
Searching for Trading: Position Average Price and Trading: Position Size source code
View Count: 468
[2021-03-11 21:45:55] |
glacialspring - Posts: 26 |
I tried text searching for these studies in the ACS_Source folder but could not find them. I found some other Trading: prefixed studies but did not find these and some others. Where can I find them? thx
[2021-03-11 21:50:01] |
The source code for those studies is not available.
[2021-03-11 21:51:39] |
Then are those measures not available to be used in our own custom studies?
[2021-03-12 03:59:47] |
Yes they can. You can access the data from those built-in studies. Refer to: ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
