Date/Time: Mon, 24 Feb 2025 12:01:24 +0000
Setup
View Count: 420
[2021-03-11 15:47:40] |
DayTraderEsad - Posts: 121 |
I am reading step #7 (copied below). Since I have TT and only trade ES/NQ (CME) - which data do I use, the Denali feed or the CME exchange? I do have the sierra with Denali bundle package. 7. If you only require data from CME, CBOT, NYMEX, and/or COMEX, then activate the new Denali Exchange Data Feed for market data. This is a new data feed providing a lower cost, supporting 2 simultaneous connections and no symbol limits. Be sure if you are using the Denali Exchange Data Feed that you are running version 1944 or higher. Update with Help >> Download Prerelease from within Sierra Chart to update to the latest version. Otherwise, follow the Sierra Chart Exchange Data Feed Set up Instructions to activate and pay for the Sierra Chart Exchange Data Feed for market data. You will need to activate the exchanges that you require. In the case of CME data, normally you will be activating one of the CME Group exchanges. |
[2021-03-11 16:50:51] |
John - SC Support - Posts: 38116 |
You need to use the Denali Exchange Data Feed and you will enable the appropriate CME Exchanges when you get to that part. You do not need to worry about the Sierra Chart Exchange Data Feed, as that is for other exchanges that you do not need. You will find the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
