Date/Time: Mon, 25 Nov 2024 18:44:35 +0000
spreadsheet triggers do not appear
View Count: 1041
[2014-03-03 04:07:56] |
User35923 - Posts: 1 |
Hello Support, I am using the spreadsheet system for trading and have created some triggers. Any time adjustments are made to the chart, the buy entry, and buy exit arrows disappear from the chart. They only come back when I change the size of the arrow styles. I'm using SC version 1100. Thank you. |
[2014-03-03 04:49:43] |
What adjustments to the chart are you specifically referring to? The general reason why you would see what you do is explained here: https://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#DisappearingArrows However, the way you are describing this, it does not make sense why this would be occurring. There also have been no changes in this area which would cause a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
