Date/Time: Fri, 11 Sep 2026 05:31:52 +0000
Data feed issues 1500v is showing wrong data.
View Count: 744
| [2021-03-11 15:37:55] |
| Tom8toez - Posts: 29 |
Please see attached screen shot. My 1500v chart data is showing days instead of daily volume. Was working yesterday. Ive tried a few triage steps, but nothing is working.
Date Time Of Last Edit: 2021-03-11 17:05:24
| [2021-03-11 15:41:03] |
You are looking at the June contract which is not active. Go back to March. You can do this through Chart >> Chart Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-11 15:41:11
| [2021-03-11 15:50:06] |
Yes. sorry, I had it at March, I only added June to see if I had to manually roll over. I am getting the same issue. When I switch to time based chart this does not happen. It seems like since this morning volume is low, it does not know how to calculate the volume data. March: Volume based chart 1500v http://www.sierrachart.com/image.php?Image=.png March: Time based chart 3min http://www.sierrachart.com/image.php?Image=.png Date Time Of Last Edit: 2021-03-11 17:05:42
| [2021-03-11 17:00:58] |
| John - SC Support - Posts: 47841 |
What you are seeing matches what we see as well. There just has not been a lot of volume, therefore you are not getting a lot of bars per day. The past couple of days have seen more volume and you also are reflecting that in your chart. Everything looks proper.
| [2021-03-11 17:27:20] |
Might be good to use a Continuous Futures Contract chart and set a volume-based rollover: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
