Date/Time: Mon, 24 Feb 2025 12:25:48 +0000
drawing disappearance
View Count: 610
[2021-03-11 15:33:38] |
User449637 - Posts: 3 |
I have a problem of drawing disappearance on some charts (where all the drawings have disappeared) and not on others. And I also have a problem copying to other charts even for designs that have not disappeared.
[2021-03-11 16:11:30] |
John - SC Support - Posts: 38116 |
If the charts rolled over to a new contract month, then you would need to make sure that you also had the drawings update to the new contract symbol. You can do this by selecting Chart >> Update Chart Drawings to Current Symbol or each chart where you have this problem. Refer to the information here: Chart Menu: Update Chart Drawings to Current Symbol (Chart menu) If this is not a rollover issue, then we would need to know what exactly happened when the drawings disappeared? Keep in mind that you can delete drawings on a chart to which they are copied. In terms of copying drawings to another chart, refer to the following: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Let us know if you are still having an issue after reviewing the above information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
