Date/Time: Mon, 24 Feb 2025 12:39:30 +0000
Denali live data with tradovate
View Count: 649
[2021-03-11 14:21:00] |
simonklaff - Posts: 3 |
Hello Sierra Chart team, about one month ago I started using Sierra with a CQG data feed from my broker Tradovate. This feed was only for Sierra and cost me 15$ per month. But I wanted the additional features that come with the Denali feed so I started using it and I quit my additional CQG feed from Tradovate. Now I just found out I have to connect once per month with my trading account to receive live data. My question is, do I really need to pay these 15$ just to connect once a month or is there a better and cheaper way to do it since I think that would be just a waste of money. Thanks |
[2021-03-11 15:47:35] |
John - SC Support - Posts: 38116 |
If you still have your account with Tradovate, then it is just a matter of connecting your Sierra Chart to that account. You would follow the Setup Instructions at the following link to do this: CQG Trading Platform Service: Setup Instructions You do not need to pay for the CQG data. You just need to have the CQG for trading in order to qualify for the Non-Professional CME Group exchange fees. If you no longer have a funded trading account, then we would recommend the following service: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
