Date/Time: Mon, 24 Feb 2025 12:34:24 +0000
"FGBLM21-EUREX CB M" to "FGBLM21-EUREX CBV M"
View Count: 616
[2021-03-11 07:31:01] |
Massimo viale - Posts: 2 |
what's the difference and to how to change my chart from "FGBLM21-EUREX CB M" to "FGBLM21-EUREX CBV M" thank you |
[2021-03-11 15:02:26] |
John - SC Support - Posts: 38116 |
CB tells us that the chart is a Continuous Contract (C) and is Date Rule Back-Adjusted (B). In other words, the Continuous Contract Setting is Continuous Futures Contract - Date Rule Rollover, Back Adjusted. When you see CBV that means that it is the Volume Based Rollover Back Adjusted. In other words, the Continuous Contract Setting is Continuous Futures Contract - Volume Based Rollover, Back Adjusted. Refer to the information here: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-12 02:50:33] |
Here is a table explaining this: Continuous Futures Contract Charts: Text Indicator Description Table Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
