Date/Time: Tue, 26 Nov 2024 00:57:27 +0000
Can someone tell me AMP Rithmic support CAC40?
View Count: 1328
[2014-03-03 00:37:34] |
User63137 - Posts: 8 |
My datafeed is AMP/TTnet but CAC40 isn't available on it. CAC40 can work on CQG but Sierra Chart+CQG is not easy to use. Anyone have experience of trading CAC40 on Rithmic? thank you. |
[2014-03-03 00:42:38] |
Sierra Chart can be used with CQG at this time. However, we still need to set up the symbol settings for the CAC 40. Information about CQG can be found on this page: http://www.sierrachart.com/index.php?l=doc/CQGTrading.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-25 02:38:40] |
Could you explain the total data feed cost of SC works with cqg if I want to trade DAX and CAC40 only? Thank you. |
[2014-03-25 04:21:10] |
35 USD for the data feed 31.5 USD for EUREX 57.75 for Euronext indexes. This is for the CAC 40. We will be releasing support for this exchange tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
