Date/Time: Mon, 24 Feb 2025 12:13:03 +0000
Delayed data for FTSE 100
View Count: 598
[2021-03-10 11:10:28]
User547503 - Posts: 3
For both CME and LIFFE, the FTSE 100 data is not working. SP 500, crude oil and currencies are working fine. But FTSE 100 comes up blank on delayed data free trial. How do I fix this?
[2021-03-10 17:06:44]
John - SC Support - Posts: 38116
What are the exact symbols that you are trying to open for the FTSE 100?
[2021-03-11 00:04:17]
ZH21-LIFFE
I also tried:
FT1H21-CME
UVH21
I even tried the June contracts M. But the quoteboard is blank for some reason
[2021-03-11 14:32:39]
FT1H21-CME is rarely traded and there is no intraday data. If you open a Daily Historical chart for that symbol you will see the data and how little it trades.
ZH21-LIFFE should not be a problem, on the other hand. You should get data, but it will not be streaming. Since you are not signed up for Real-Time data for the exchange you will only get the Historical data which updates every 20 minutes or so (depending on your setting) and is 10-15 minutes behind.
If you are still just getting a blank screen for ZH21-LIFFE then we need to see your Message Log following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-03-11 16:57:23]
Thanks John for clarifying. Yes I got data on the DOM for LIFFE. Cheers for that
