Date/Time: Mon, 24 Feb 2025 10:29:25 +0000
CQG Footprints difference between computers
View Count: 458
[2021-03-10 09:29:12]
DenysL - Posts: 3
Hiya,
I have 2 different datafeeds with CQG provided by my broker (each on a seperate computer). When looking at the footprints and the number bars calculated values study, I notice that there often is a difference between the values between the 2 datafeeds. Is this just because of the poor quality of the CQG Datafeed as I have read in the sticky post made by the engineers or could this be another issue?
Engineers post: Sierra Chart Does Not Recommend CQG (Various Reasons)
Cheers!
[2021-03-10 16:55:42]
John - SC Support - Posts: 38116
If you are seeing differences in data feeds, then most likely it is related to the underlying data.
But, you should ensure that all of the other information is exactly the same between the charts to ensure that there is not some other setting that is causing the data to be different (such as Session Times, study Inputs, etc.).
