Date/Time: Mon, 24 Feb 2025 09:13:20 +0000
Ask Volume Bid Volume Difference Text - pullback column value
View Count: 422
[2021-03-10 06:56:37]
User19165 - Posts: 346
In watching the pullback column, I am finding the number bars 'delta' column is too far away from the pullback column numbers. I was hoping to use this indicator above but it doesn't seem to work with the pullback column. Would you consider adding pullback column as a toggle in this indicator?
