Date/Time: Mon, 24 Feb 2025 09:03:19 +0000
Chart not working
View Count: 413
[2021-03-10 04:02:28] |
User861208 - Posts: 11 |
Every time I try to create a new chart in my chartbook it is black screen only. I was trying the 10 and 30 year treasury to create an inverses correlation study. I simply find symbol and nothing appears but a blank black screen. thanks |
[2021-03-10 04:26:43] |
You need to activate the CBOT exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Or use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
