Date/Time: Mon, 25 Nov 2024 18:25:44 +0000
Bid-Ask Volume Coloring in Volume by Price Studies won't work...
View Count: 1129
[2014-03-02 04:47:18] |
User32628 - Posts: 15 |
I've tried just about everything to make it work but I can't get the bid-ask volume to color differently. I have set the colors differently and chose to make them visible. I have selected Separate Bid/Ask Volume Coloring. I have modified the Global data settings to tick, I have tried both IQFeed and IB, I have selected ignore and disabled Point of Control and Highlight the Value area. What am I missing?
[2014-03-03 00:47:02] |
You need Bid volume and Ask volume data for this to work. Information about this is documented here: http://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#BidVolumeAskVolume IQ Feed does provide this data historically and in real-time. However, be sure to follow the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php With Interactive Brokers you will only get Bid volume and Ask Volume for data received in real-time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
