Date/Time: Mon, 24 Feb 2025 09:19:34 +0000
replay control panel
View Count: 502
[2021-03-10 00:16:39] |
User21339 - Posts: 61 |
Control panel for replay is not opening. can you address this in next update. using 2238 and wont open for any chart. play pause etc works on the dropdown but the control panel doesnt show as it used to. |
[2021-03-10 14:12:24] |
John - SC Support - Posts: 38116 |
Refer to the following: Replaying Charts: Chart Replay Window Not Visible For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
