Date/Time: Mon, 24 Feb 2025 09:44:21 +0000
How to multiply some studies
View Count: 531
[2021-03-09 20:34:44] |
User44790 - Posts: 21 |
Hello, I would like to ask you which study to use if I want to multiply any study, for example if I want to just multiply ATR study *2 or something like this? Is it possible? For example I want to multiply ATR value*100 Thanky you |
[2021-03-09 21:45:06] |
John - SC Support - Posts: 38116 |
Refer to the following: Using the Basic Arithmetic Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
