Date/Time: Mon, 24 Feb 2025 09:00:36 +0000
Keep Same Tool When Selecting Different Chart in Chartbook?
View Count: 494
[2021-03-09 20:22:37]
absorrel4 - Posts: 97
How can I select a tool for any chart within my chartbook and have it used on every chart without having to select the chart and then select the desired tool again and again? For example...I am using Vertical Line on Chart 1 and when I switch to Chart 2, I do not want to specifically select vertical line again after switching to chart 2 (the default for each chart is to remember the last tool that was used on that chart and that tool will be the default tool when I come back to that chart). I simply want to be able to utilize many different tools and select the tool one time and have it utilized for every chart in the chartbook without reselecting the tool over and over again as I move thru the various charts within the chartbook.
[2021-03-09 20:31:53]
John - SC Support - Posts: 38116
Set the following setting to "Yes":
Chart Drawing Tools: Use Common Drawing Tool for Charts (Global Settings >> Tool Settings >> General >> Tool Options)
