Date/Time: Mon, 24 Feb 2025 09:20:57 +0000
resizing price axis issue with one chart (no control key needed for resize)
View Count: 458
[2021-03-09 18:43:50] |
User504980 - Posts: 24 |
I have a Reversal/Numbers Bar chart that I got from an external resource that, when I left-click the price axis and drag, it resizes the price scale. All my other charts require that I hold down the control key to resize. Is there a setting that I need to look for to get this one chart to act like all my others, so that dragging without the control key simply slides prices up and down?
[2021-03-09 20:06:13] |
John - SC Support - Posts: 38116 |
Yes, it just means that that particular chart has the selection for "Interactive Scale Range" selected, whereas your other charts have "Interactive Scale Move". The CTRL key then flips the action to the opposite one. Refer to the following for more information and how to change the selection: Chart Scale and Scale Adjusting: Interactive Scaling For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
