Date/Time: Mon, 24 Feb 2025 09:46:12 +0000
Denali data feed/TransAct DOM
View Count: 452
[2021-03-09 17:02:56] |
User259545 - Posts: 24 |
I am using TransAct for my broker and the DOM that they provide, which I have been using for many years. Currently I see only 10 levels up/down on their DOM, but I would like to add the Denali data feed so that I have access to the full book. My question is, will the Denali data feed/display on my TransAct DOM or will I have to use your DOM. I talked with TransAct support and they could not give me an answer. Thanks for your time and effort. Best Regards, Brett Walker |
[2021-03-09 18:58:38] |
John - SC Support - Posts: 38116 |
The Denali Exchange Data Feed only works with Sierra Chart. Therefore, you will only see the entire order book within the Sierra Chart software, you will not see it in the TransAct DOM. You can use the Sierra Chart DOM to trade with TransAct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
