Date/Time: Mon, 24 Feb 2025 09:23:46 +0000
CQG configure in SC
View Count: 418
[2021-03-09 15:55:48] |
User651232 - Posts: 6 |
I shift to CQG, how can I configure CQG in Sierra Chart? I read the notice of transition to direct SC billing, so I am with AMP using SC package 3, which is free. Thus I will be not affect by this, is SC package 3 still free with AMP? |
[2021-03-09 18:07:47] |
John - SC Support - Posts: 38116 |
To connect your Sierra Chart software to CQG, follow the instructions here: TT Based Order Routing Service: TT Interruption | Post: 252374 You will be transitioned to paying for your Sierra Chart for April. There is no longer a free version of Sierra Chart. Package 3 directly to us is $26.00 USD per month. Note that you have a separate account that you are using and should continue to use. This is not the account that you have posted from. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
